Airbag light.
well, checked the connection under the seat.... the light went out for a day or so and then proceeded to come back on..... poo.
Check continuity (ohms) of the roll connector (clock spring) while you're turning the steering wheel. It should remain steady thru out the entire range of movement.
I have this problem in my project car, so I might try this as well. Where/what is this?
