Ryan
There is a good possibility that I may go hybrid with an EJ257 short block with my existing 2.0 heads. Aside from the obvious things that I will need in order to do this, such as engine management and STi engine gasket kit, other things such as stock fuel injectors, fuel pump, turbo, water pump, and oil pump can all be used with the STi short block (probably should replace the oil and water pump)? At this point, I just need to get her back on the road, but if I can easily do a short block swap instead of repairing my old exsisting WRX short block, then that's what I want to do. Money is tight right now, but in the future if I have better finances, I will have a nice STi short block to work with
ANY info regarding hybrid set ups is appreciated!
