jackfortune
With 149k on this original turbo ('06 Legacy GT Limited), I pulled the original banjo bolt/filter for inspection. As you know, many Subaru turbos have failed prematurely (infrequent oil changes, poor quality filters, poor quality oil, failure to idle up on start or to idle down on shutdown which causes oil coking in the feed line to the turbo). Now, this vehicle has had Mobil 1 5W30 and Subaru filter changeout every 3750 since coming off the dealer's lot. I was amazed to observe that the banjo bolt filter was not sludged at all! I found one small speck of metal trapped on the inlet side of the filter. This seems to be good empirical evidence that the problem is not with Subaru's turbos/engineering, but rather with operator negligence. I would say never buy a turbo Subaru without pulling out the banjo bolt/filter for inspection....it won't lie. The Subaru part number for the revised banjo bolt is "Union Screw-Filter Assembly #14445AA090"...yes this is a revised part....the filter is made of a better grade screen. Don't forget to replace the two copper crush washers...one on the block side of the union, and one on the bolt side of the union...Subaru part number "Gasket-12x16x1 #803012040. Yes, I replaced the parts, and saved the orginal bolt/filter as an exhibit for the next owner. If you own a turbo Legacy, and want to check out/replace your turbo oil feed filter bolt, feel free to give me a call, and I'll walk you through it. It's a real trip, and large hands are a handicap! You can also go to LegacyGT.com for some very useful tutorials on the removal/replacement procedure:
http://legacygt.com/forums/showthread.php/2-5gt-turbo-oil-supply-banjo-bolt-filter-removal-62371.html?t=62371&highlight=banjo
and
http://legacygt.com/forums/showthread.php/passenger-side-turbo-avcs-oil-line-summary-136078.html?p=2921480
If you ask a dealer to do this for you, hold on to your wallet. They hate doing this job....even though it should be done every 60k to err on the safe side. [email protected], (207) 975-6531 (cell), (207) 832-5861 (land line).
An... if you need to verify part numbers, remember that SubaruFAST is a great resource. The following link will provide a tutorial to download and mount SubaruFAST as a virtual CD drive:
http://www.sl-I.net/FORUM/viewtopic.php?f=14&t=20811
and
