Clutch issue?
Spiller1327
In my 2000 OBRS first gear tends to rattle the car when just taking off, I had the clutch replaced maybe 10 thousand miles ago(I put loads of miles on cars, that's only like 4 months of driving) It only happens in first gear and stops once you get moving 5 miles per hour. Ray said Motor mounts are getting bad, but everyone else I talked to said that wouldn't be it and they were looked at by a pro when the clutch was done. Someone else said my slave cylinder could have a tiny leak and put a little oil on my clutch but it burns off when u get moving. I'm not sure what is is. Any ideas? Thanks
P.S. The motor is still junk I just thought i'd get this off my mind.
Yeah, it shutters in first gear when i am taking off from a stop and I think everything was replaced when it was done.
soiunds like oil leaking onto clutch plates, mebbe rear main ?
do car do this only after sitting a while, or every time taking off in 1st
I guess both because it does it a stop lights also. One of my friends said that as well. It's a definite possibility.
