coolant crossover pipe/crank pulley/cp bolt and other stuff.
Matt
title says it.....
im in of a coolant crossover pipe, prefer a wrx pipe but I can make others work.
crank pulley
crank bolt
.....timing belt parts.......
sohc timing covers...all 3
crank gear pulley
just to the right of that is another geared pulley
all the other smooth pulleys should come with a new tbelt kit.
thanks guys.
the cogged bearing is part if the timing kit.
ive got all the other stuff, im pretty sure I have the timing covers
I figured you might!!! let me know what you want for that stuff and ill see about picking it up.
???? whats it worth to you sir....worst I can say is no and your stuff is so overpriced and ill never buy anything from you again!!!!! but really, let me know,cash, manual labor, running stuff over with the dozer? what ever you need!!!
I'm really just guessing here but like 75-100 bucks? If I'm way off let me know. Inski, not really sure what else I need just yet.
I bet Mike has some of that.
cool thanks mike, let me know if I need to pull the parts or not, ill bring tools if need be and when I can swing by and grab it. thanks again.
