Cooling fans not working
25guy
Soo I've done some chasing tonight and so far
All fuses check out
Green plug under dash plugged in relays click
Played musical relays same issue.
Tested each relay 90 ohms they're good.
Wires look clean no chafes.
Fans work with direct connection.
Temp gauge in my dash works.
So I am at a lost I heard rumors of a second "thermometer" don't know where it is or how to find it google isn't being very googley
Any help will be greatly appreciated guys and gals thanks!!!
Sent from my SM-G900R4 using Tapatalk
The green plug isn't suppose to be plugged together that is for reflashing only and there is a coolant temp sensor in your crossover pipe under your intake
It's below your pcv valve and iac it's a brownish colored plug and I'm pretty sure the plug is also a triangle
Well, I tackled it the other night. It wasn't the sensor... 30 bucks down the drain. I'm not going power to my relay block. So in the mean time I just ran a jumper from the battery to the relay block. They kick on when the ecu tells them too now.
