Dohc heads and intake
Matt
I'm looking for a set of Dohc heads and intake from a 97-99 impreza/outback. Need to be complete with valve covers and as complete as possible intake. I have cash!!!
I have an intake mani and tb from a 2000 RS...
Whoops just noticed 97-99
i have a intake you can have
actually i think i have a set of heads too that will need a going over by a machine shop
Cool. If you know for sure ill take them. I work with Zach Nason, I forget his name on here but his dad owns nasco which is an engine machine shop.
These heads are so small and beefy they rarely warp. But you're doing a turbo build, you want them surfaced regardless. I can pick you up a set from the junkyard, there are 5 or 6 DOHCs in there, and plenty of intake manifolds.
Why 97-99 impreza? that's when they changed over to a phase2 engine. That intake manifold won't work, anyway, you need a DOHC manifold only on the DOHC heads. I actually have one, I think it's missing the EGR solenoid or something.
the ones i have will need valve work. some of the valves leaked. i probably have a set of cam gears and timing covers too somewhere
I have a 2.5dohc that runs solid, resealed and serviced with no knocking, willing to let go cheap, cheaper if you pull the motor yourself.
500, its still in the car if you want to hear it run, the exhaust has been taken off so its loud but it ran great on the highway before I started parting it out. I have a stack of service records over an inch thick that have been kept since the original owners bought it.
