drvsdwz
DRiVe SiDeWayZ
Hey all,
I got to thinking and am contemplating on going this route, but not quite sure how I should go about it. Suggestions from people with experience on this topic would be appreciated.
If I go this route, I definitely want a built bottom end. Forged pistons, rods and crank with arp studs. My dilemma, should I get the Rallispec built shortblock for $3500, or should I purchase the pistons, rods and crank seperately? I feel like the cost will most likely be the same, and if for some reason the rallispec block pooches, at least I will have another shortblock on hand....
More times than not, you most likely need to machine the cylinders for the latter, which means a longer time that I will be without my vehicle.
What are your thoughts?
Justin
Justin
