4WRXter
Skier!
So, after changing rotors and pads on our FXT, I have something rubbing only when I turn left. Somebody tell me what is causing it.
KIDDING! Actually there is a noise. Only when turning left. But I know even you experts can't diagnose noise over the web.
I took everything apart this morning and re-assembled. Still noisy. I went and did some things with my truck, came back and disassembled again. This time loosening and removing one part at a time. Caliper first, caliper bracket, and so on. After removing one piece I would turn the rotor, trying to hear the noise. I took everything off and re-assembled in the same manner. Listening after installing each piece. Something still rubs when turning left. It's not bad,bad but pretty sure it is metal to metal.
I am running WRX wheels (incorrect offset) but didn't notice rubbing last winter. And this sounds more metallic.
I guess I'm(my wife is) going to drive it a couple of days, then I will disassemble again to look for a shiny spot where rubbing is occuring.? I don't know what else to do.
