Yes, exactly that. As speed increases, the "whump" sounds come closer and closer together.is the noise lounder as you go faster, or does it change in relation to speed whump whump whum going slow then whumpwhumpwhump
bad wheel bearings often make a whumpwhumpwhump noise, and will change as you load suspension differently, like turning left or right
cupped tires make a very similar noise, but are less affected by loading susp back and forth
If it sounds like a helicopter it is probably a broken tire belt. Several years ago I put on expensive ( for an outback ) 225x60/16 Goodyear triple assurance 80,000 mile tires. They became soo loud at 35K I had to junk themhow about a broken belt in a tire
I was going to say the same thing. I bought brand new tires and like 6 months later one of them threw a belt.how about a broken belt in a tire
