now I have the options of chosing my recovery tool:
Startup Repair
(Automatically fix problems that are preventing Windows from starting)
I finally decided to click on that (even though I'm quite sure it was hat I was running at start up), and will let it take it's course.
System Restore
(Restore Windows to an earlir point of time)
If I click yes I get this: To perform an offline system restore, you must specify which Windows installation you would like to restore. For example, if the installation in "C:Windows" should be restored, enter the following command: rstrui.exe /OFFLINE:C:Windows
Windows Complete PC Restore
(Restore your entire server or personal computer from a backup image)
I clicked on this thinking nothing was happening, then I just so happened to see it behind the big list, so I looked at it and there was this scanny thing looking for backup disks. Then the exclamation point popped up saying: A valid backup location could not be found. Windows cannot find a backup for this computer. Attach the backup hard disk or insert the final DVD from a backup set and click Retry.
Uhmmm no thanks.
Windows Memory Diagnostic Tool
(Check your computer for memory hardware errors)
When I click "check for errors" it does NOT restart and then it tells me: Windows can NOT check for memory problems. A problem is preventing Windows from checking memory problems during start up. Try to check for problems again by running the tool manually. WHAT TOOL?!?!
Command Prompt
obvious what this does, which I've used the command prompt in the past, but never for anything this serious, so I am scared to death to type anything, and if I did, would it even do any good?
TOSHIBA Recovery Wizard
has the SCARIEST message, it gets all black and red and says: WARNING! When the recovery is executed, all data will be deleted and rewritten. If you are restoring from a backup, did you make sure to backup all important data and cnfigure Windows the way you want it restored? Please connect the AC adapter.
HELL NO - I HAVE NO CLUE WHAT THAT IS, AND AM NOT TAKING MY CHANCES!!!
So much for going to bed 2 1/2 hours ago.
I hope I can get the neccisary help in the morning. Thanks Spin.
