Keep Blowing Lights
Fatson
Hey i got a '04 2.5RS and keep blowing the same tail light? I checked the ground and checked the pigtail harness and the contacts, also the fuses and so on....y would the SAME bulb keep blowing other then those things i checked because they were fine.....ne ideas at all would be nice
sounds like you got a short someplace. look carefully at wiring to taillight, esp where it goes thru metal bulkheads n such. lots of the wriing is in conduit to protect it, but some is not...that's probly where the short is. it'll be a PITA to do but until you find the short, you just need to carry a 6-pack of replacement bulbs!
maybe the wiring got damaged by cargo in your trunk, check in there first.
