metcalf164
IWould anyone in the portland saco area be willing to switch a few sensors so I can avoid buying a buying a whole lot of new ones that aren't the problem.
The problem I have is the turbo will not build past spring pressure. All lines are correct no boost leaks. I pulled a code for a/f sensor every once in awhile I did bench test it and it work the way its supposed to. I also got a code for air temp once. The car is also running rich and I think that is what may set off the 02 sensor. I think the computer may be running in safe mode. Everything seems to be working the way it is supposed too or so it seems
I am running an ap with green turbo external gate and all supporting mods. The boostt worked greatfor about 800 miles after I put new forges pistons in it. Then it just stoped I reset ecu and no change. I have run out of ideas. So if anyone can help me out or give a few idea that would be great
I was not sure where to start this thead so if its in the wrong place please move it
Thanks and hope to make it for the drive on the kank
