Buck Rogers
Anyone else have a case of piston slap that was actually fixed for good? A little history here, 05 Baja N/A 5 speed, Charlies replaced 2 pistons and all rings at 24000 after I complained to SOA. Got the standard bull**** from the dealer about its normal if it goes away when warm, problem is it took about 30 minutes of running to warm up enough. When you use your car for lots of short trips in the winter the noise was driving me nuts. Hence the performance exhaust which helps distract from the slapping. The slap came back at 40000 and my original warrenty is out now (70000) I have an extended 5 yr/100,000 not sure who wrote it at the moment but I can locate it . So is this a resolvable issue or am I destined to live with it? BTW on warm 80 plus degree days its not bad, but this is Maine, sooo those are rare.
Any help/advice is appreciated
Buck
Buck
