TheSoundMan
Ok, so as you might have seen, ive been experiencing some boost issues. Iv'e been working with meyagi to figure it out, inski seems to think that putting this out there might spark some ideas from some of you.
So, the problem is this, no matter what gear im in, i can only build to about 7-8 PSI.
1) we checked everything for exhaust leaks, and there are none.
2) we checked everything for a boost leak. Found a tear in the inlet pipe, I have a new one on the way, but in the mean time we sealed the tear with super glue, and I have subsequently checked it for leaks, I had my fiancee rev the motor up while I sprayed some carb cleaner on the 'repaired area' and got no response from the motor, and none got sucked in. we had initially thought that this was causing it to run leaner and pulling timing, but as stated, i believe that that can be eliminated for now.
3) we checked the wastegate actuator, and it moves freely, no snags, it does not get caught up anywhere on its range of travel, and moves smoothly.
4) I cleaned and checked the boost solonoid (stock) connect the green test connectors under the dash, and it opens (not fully, but enough to let air through)
