Redline
Member
I had a whiney pump (and major leakage) so I replaced it with one I got from Nigel. It came off an RS, so I had to change the nipple fitting to hook up the pressure hose...
When I'm turning the wheel, (hi and low rev) in one direction, I have continuous power throughout. However, when I quickly turn back the opposite direction, I find myself fighting the wheel. This is extremely hard to contend with on an Auto-X course, and I need to resolve this.
My fluid is at level, and I'm running Valvoline hi-mileage. There isn't any belt slipping (no squeal, at least). I do not hear any pump whine, and there aren't any leaks anywhere I can see. I've yet to inspect the box up close, though...
Ideas? Shorty thinks it might be the box itself, since all the Pump does is provide constant pressure - not alternating... since it only appears on the rebound (reverse steering direction) and not throughout the turn.
HALP!
HALP!
