Mark Active member Sep 3, 2010 #2 of course the day a hurricane is supposed to breeze through I hit a bump and my power windows don't work. now my drivers side is 100% open and i need a fix. i thought maybe a fuse, but i can't find a fuse that would refer to windows. any thoughts?
Mark Active member Sep 3, 2010 #3 i should add. the drivers side control doesn't work, the pass side control doesn't work, and the sunroof, albeit closed, doesn't work
Meyagi I'm a hack Sep 3, 2010 #4 its a wiring problem. ive seen it before, if your near standish today i can prob fix it for you in like 30min
Mark Active member Sep 3, 2010 #5 ugh. unfortunately not. i'm just hoping it doesn't rain till i can get home around 8 what's the issue with it?
