yeah it's from a version 6 Jdm sti5 speed?
the final drive is 4:11 this is basically a quick fix until I can afford a 6 speedwhats the final drive ratio? any particular reason you chose this trans, your fxt trans is as strong or stronger then a jdm 5mt
Im driving down to NashuaAre you driving down to Nashua or is Roberto coming up here to deliver it?
Thanks man I was going by what I was being told on other forums, usually I do my research.The only JDM STi 4.11 trannies are ver1 and 2.
That transmission you are buying is from a ver6 WRX.... probably not stronger than a rs or wrx gearbox by much..
SOURCE:
http://www.gearhack.com/myink/ViewPage.php?file=docs/Subaru%20Transmission%20Chart
