EvilAsPie
So, we were bleeding the brakes on the 93 legacy today. We had just put 03 legacy front calipers on with SS lines all around and newer pads in the front.
While putting fluid back into the system i started with the FR, then RL. That half of the system bleed fine. Got the FL and when i opened the bleeder only a little bit of fluid/air came out and the peddle wouldn't reach the floor. The same thing happened with the RR. I even took the line off of the caliper in the front and the same thing happened.
The ABS light has been coming on, happens the second i touch the brakes. The brakes have felt ok.
I think Rad had said he had had the abs fuse out, but i don't know if he had it out because there was a problem or because he didn't want the ABS, Rad?
All the fuses are in it now, but one of them that is supposed to be a 10 is a 20, Rad?
I don't think it is electrical though, because the system seams to be not working with the car off.
But could it still be a problem with the ABS pump?
Whatever it is it has to be somewhere between the MC and the ABS pump since both front and rear wont bleed, right?
Any ideas?
Any help appreciated. Thanks.
Any ideas?
