Turn Signal Issue
Pedro
٩(͡๏̯͡๏)۶
Ok this is happening on my coworkers wifes car (so I don't get to see it first hand)
When engaging the turn signal it will flash quickly aproximately 10 times then return to normal speed. This is occurring on one side only. and the lights are all functional.
The car is a 2000 Outback.
any ideas?
I was thinking the flasher might be on it's last legs. and that is probably the quickest check.
any ideas?
spooks in teh flasher
or coffee/dog hair/assorted ca-ca in the turn sig stalk
replace the bulb. it will flash really fast when bulb is bad or going bad. Also, if you have a "jumping" ground. Check for that also.
that happened to the 98lgt just replace both blinker bulbs on that side and it should return to normal....the signals will usually act up if a bulb is about to die.
will advise.
I have never had that problem if the bulbs still work. that is the only reason I didn't suggest that to him in the beginning.
