you can out brake the ABS even while it is on. It is the same procedure as if you didn't have ABS. let off, get back on.FYI, I have blizzaks and I still think ABS sucks. Its almost like you can feel the car ready to stop and then the ABS keeps you rolling/sliding. Annoying as hell, ABS is useless in snow. There should be a sensor for weather that automatically shuts them off in snow.
^Bingo!if you keep getting ABS engagement in snow, it's not an ABS problem, you're braking too hard for available grip
brake just up to threshold of ABS and you'll be good. if you just want to mash the brakes and lock em up, pull the fuse.
ABS can educate you brake foot pretty good, actually
Two miniature blade connectors, inline fuse holder (with same size fuse) and a switch.Hmm, here I was thinking about adding a swtich for ABS that would void some part of the warranty. Pull fuse.... why didn't I think of that. I always check fuses first when something stops working, I should probably start there when I want to disable something.
^Logically. I like your disclaimer, lol. BTW where could I pick up these blade connectors, or are you just talking about the male end from a crimp on blade connector? I assume I can get an inline fuse holder at the autoparts store or radio shack right?if you were to get into an accident with this thing activated, and it were found, you would likely wind up in deeper doodoo.
*for offroad use only
*Pedro accepts no responsibility for driver inadequacies, stupid behavior, or cranial-rectal inversion resulting from this mod.
2009 all rights reserved Pedro LLC
Yeah but then I need to go through all the effort of bending over to do it and stuff.umm, lads...exactly how hard is it to pull fuse #8 on your fuse panel?
pull fuse, no ABS
stick it in, ABS back on
you can get the mini blades at any autoparts store. you can also snip one of the legs off the "slide under bolt" type connectors too.^Logically. I like your disclaimer, lol. BTW where could I pick up these blade connectors, or are you just talking about the male end from a crimp on blade connector? I assume I can get an inline fuse holder at the autoparts store or radio shack right?
I thought the same thing. And actually deliberately blew a fuse. So next time it is really snowy I can play around with and without ABS on my studded tires.I would at least put a blown one in there
