RyanR
Probably turbo or valve seals.  Pull off your intercooler and see if it has a ton of oil in it.  Then, pull off your downpipe and see if the turbo shaft has much play to it, and if you can see oil/oil sludge in the exhaust housing.
Does it puff smoke when the car is hot, but you idle it for a while then hit the gas?
You could have an exhaust leak that is causing the white smoke to come out of the hood scoop as well.
