Update! (finally, been busy)
Ended up getting out of my blown motor scare with just a coil and plug. Awesome.
Installed a mishimoto throttle body coupler, eBay stainless exhaust, and a PTP lava turbo blanket. Throttle body coupler wasn't the easiest to install, but it works a ton better than the beat up leaking stock unit. It's red too! The blanket also wasn't the easiest to tie to the turbo with big hands, but I got it on there good after some swearing. Made a good difference in the butt dyno and intake temps are definitely lower overall. I definitely reccomend.
I need a fuel tank for a sticker, buying a used one from fleabay along with a dw65c fuel pump and shiny new capped lug nuts. Excited about having a nice pump, one step closer to the 300hp club! However, the fact that the rear subframe needs to come out to replace the tank is a bit retarded...
Pics eventually.
Pics eventually.
