inelement207
Ok so question what does WGDC High and Low represent? adjust both?I take it back. Your TD Boost error swings negative just slightly at that RPM, adjusting the initial WGDC's slightly lower for the rpm range just before that would correct the issue and give you a cleaner pull. If you have access tuner race, drop the 3400 RPM WGDC by 1 percent under full load.
and boost drops consistently in 3rd gear pull at 3400 RPMS where it reaches the target 16.5 and returns to high values by 3800 RPMS. Race tuner has a 3200 and a 3400 row, adjust both or one down?
reading ACCESSTUNER SOFTWARE CALIBRATION & TUNING GUIDE FOR SUBARU off coarse before I head into work already understanding some
MAP v331 91
pull spreadsheet https://docs.google.com/spreadsheets/d/18y9aenTQKCH-3tB5OzXjXRxS_bWtN_wAIbO3Ch55SWw/edit?usp=sharing
