lgt_sabr not sure if I am going to the meet yet or not. I want to but not sure what the wifey is going to say. Are you up around the Topsham/Brunswick area? If so then you can hop over to my house sometime during the day. I have the tools we can pull one of your rims off and see if they fit or not. Let me know I am working from the house this week.
at the body shop i worked at the old guru said aluminum in contact with steel will cause it to rust faster than if it was steel/steel contactHow does alum ruin cast iron? There is a huge hardness diffrence.
He is correct. Being from the metal ind. I know a pretty good bit about the two and how they interact.at the body shop i worked at the old guru said aluminum in contact with steel will cause it to rust faster than if it was steel/steel contact
