Help: Horrible "rattling" noise from front of car
Stein
Stein
So ever since I had Norm's change my cat (with another used one...
) and a gasket seal thingy that was leaking, I've been hearing a bad rattling either under the hood or under the car.
Its not a piston slap, and it doesn't get any worse or better after time running that I can tell.
The interesting thing is that it happens at certain engine speeds... It happens in multiple gears and out of gear, so I rule out the tranny and clutch (although I supposed it could still be something that's always attached to the engine).
Both in gear and out, I would go through the RPMs at various speeds to replicate the sound. It happens under no to low to medium throttle between about 3100 and 3500 RPM (although it spread a bit farther when I was just testing it in my driveway), and at about 2600rpm when the engine is slowing down or I'm coasting and it falls past that point. If I give it a lot of gas, I don't gear the sound (although I still hear it when the engine is slowing down past the above points).
WTF could this be? It's worrying me that it's something inside the engine.
First on my todo list is to go back outside and watch under the hood as somebody else revs. Could it be the "new" cat? Could it be the new seal? Could the surgeon have left his pocket watch inside my car somewhere?
Lobstah, when I pick up the wires, would you probably be able to tell what's wrong just by hearing it?
heat shield
-----Added 12/3/2009 at 05:42:03-----
dang yo Jason
Yes, i'll listed to it and if it heat shield, we can fix it
OMGOMGOMG THANKS GUYS
that's what I thought, since I've heard its an issue and one vid I saw of a cone-filter intake mod said "this is the video after I removed the heat shield because of the rattling" (that last word is the only reason it showed up on google
So Lobstah, how long will it take? Would you rather do it before "brunch" or after? I also don't want to show up to my mom's work's christmas brunch with oil or engine "dirt" on my hands
So its not a possibility that there's something inside the headers or inside the heads (PLEASE GOD NO) or possibly in the cat?
edit:
I think that's it. I'll have to stick my hand in there and give it a few whacks manually.
sweet
Off to chem homework, then I'll head outside to look for this magical heatshield.
Where is it in relation to the front of the car?
sweetOff to chem homework, then I'll head outside to look for this magical heatshield.
in back of the front. It's right on the exhaust pipe, and seeing as they just changed the cat, look at that
its in back of the front?what?
sorry, I'm tired and still have to finish this chem lab.
You asked where it was in relation to the front and I was being an ass, but now ur the ass cause I had to explain that to you:lol:
Well the back of the front is the middle, right?
All I know about the exhaust under the hood is that its metal pipes that are generally hot after the car runs and are not connected to the radiator.
1. crawl under car
2. follow engine to firewall
3. cat heat shield should be right thurr
4. (optional) rip the durned thing off so it'll never rattle again
just giving u crap
you do know that it is illegal for them to be reusing converters it a federal law they are to be recycled after there use on one car not reused.that's why no junkyards are allowed to sell them you have to buy new
that's what I said in this thread right after he said they put a used cat on
Yeah I remember that, but I assumed it was fine if it never sat off a car...
I'm going to start doing some searching, but does anybody happen to have a statute number for me?
