intermittent starting
I just found out that my issue is the vent solenoid under the intake manifold. So maybe this is your issue too? There are a lot of similarities.
Could be....The newest wrinkle is, I let it warm up yesterday, let it sit for an hour or so... I went back out and started it. It started, and began to idle down, and stalled, and then wouldn't start right away.
Could it be the vacuum line on the fuel pressure regulator, or the is FPR failing?
The last time I had a car start and then stall like that, it was the idle air control valve on my Saab.
Ok, it finally died. It's at Jim Martin in Farmington. They pulled the pump and it was clogged with, "rust and/or mud". They've ordered one and it should be in tomorrow.
I wouldn't think it's rust since the tanks are plastic I believe. Possibility you've been filling up with crappy gas. Make sure they vacuum that tank out or this will occur again.
