New FB engine to go in N/A 2011 Forester
Wait...
Omg, I can see it on the brand new engine...
Right there in the pic...
The HG is already leaking,
No silly! That was one of the main things they went after on this re-engineer. Hopefully leaky head gaskets are a thing of the past. Hopefully.
ask owners of early Porsche 911s how great cam chains are......sure hope chain tensioners in the new FB are pressure-fed
increasing fuel efficiency is going to be more and more of a focus for automakers, so get used to it
longer stroke smaller bore means max torque moves down rev range a bit
back to good ole dohc, buh-bye buckets
another thing about the chain drive that people dont realize is that over time, they become loose and more elastic....most motorcyclists will know this with their chain driven rear wheel and have to retention every so many thousand miles....
plus, i would hate to see that snap and destroy everything in it's path....
Well, if the bore and stoke stay similar for the FI versions of the engine this could be a real torque monster for use through a restrictor for rally.
Cams have a whole lot less tension and torque than a wheel on a motorcycle. The older Saab DOHC chain tensioners were great. and you could replace the wear parts and reset them. I doubt that it will be that good, but there is the possibility.
I am counting on inski to let us know.
I just want a t-boned forester with the turbo diesel, so I can yank the motor and stuff it in my XT
Let's go to europe and crash a pair of diesel Fozzies, it will save us a bit on shipping...
+1 TD Fozzie! I miss my chipped TDI (only a little).
diesel boxer has 258 lb-ft torque @ 1800rpm and gets 44mpg in the legacy!
Wait, then why does the Impreza only get 40.5542386 mi/gal with the 2.0D? (5.8L/100km, check my conversion).
I too would like a turbo diesel Soob.
The legacy is listed at 5.6l/100km combined which is 42mpg. it is probably tuned differently.
My old Grand Am has a Timing Chain driven engine, it hit 212,000 miles before I spun a crank bearing. The timing chain was still in great condition when we took it apart.
