got it running seems to go well. but i blew and ic pip off and need to cut it to make it fit better i tried to rig something to make it into portland to cut it but no go. I moved the car though and hit full boost for a a first gear pull ;D. then it shut off. >
you should get a package of jb weld. lay a bead of it around the end of the tube, as tall as possible, then when it dries it will work just like a flared pipe end to stop the hose clamp from sliding all the way off.
Iam actually impressed with the new set up almost thinking i dont need a new turbo... it will def run mid 12's now. BUT I NEED MORE POWER AND WILL GET A NEW TURBO ANYWAYS. the vf39 falls on its face on highway launches. meth and fp green for the winter. then we will see.
