With my boost leak that was due to the rubber seal, I think Cobb said similar thing. I even called them.Alright so Cobb got back to me really quick. They said to try resetting the ecu first and if that doesn't work it's most likely a boost leak like you guys said and if so I should get a smoke test done. So where is the closest place to have that done and what does it run? Sent from my iPhone using Tapatalk
Yes, In my case.I was merely trying to say that I did not have the know-how to do it myself and I found that seeking help (via Meyagi in that case) was my way to deal successfully with the issue. The OP has to figure out what works best/easiest for him. I was just trying to share my experience with a similar (yet different) situation.i think jojo is referring to the plastic coupler between the intercooler and throttle body if i'm not mistaken?
