Good to know. We'll see what happens come summer- it's pretty fun for nowI had the SPT intake and SPT heatshield, and be warned, in the summer time its going to run like raisin. Even with the heat shield it gets major heat soak. I switched back to the stock air box.
love the bling! Do you have an AP yet?Good to know. We'll see what happens come summer- it's pretty fun for nowI had the SPT intake and SPT heatshield, and be warned, in the summer time its going to run like raisin. Even with the heat shield it gets major heat soak. I switched back to the stock air box.
Blue- I read that too. Supposedly the stock setup id food to 400WHP? This install was all about the bling.
Thanks for all the thoughts, guys!
Really the only time you need to get rid of the airbox is when you run a rotated turbo or a FMIC. As hard as it is to believe stock airbox FTW!Most guys on legacygt.com say to skip the intake, they are more engine bling than performance and unless you are pushing higher HR (turbo swap etc) the stock box with a panel filter does just fine. That being said i have no "real world" experience.
Are you considering using a K&N with no oil? I wouldnt ever suggest doing that, you can use electronics cleaner on a MAFS with no issues. Or get a filter that doesn't require oil to work properly.On the AEM no oiled filter, oiled filter FTL once and a while
Good deal, glad to hear it, other than the warmer air, the spt generally shouldnt mess with A/F much at allThe SPT is an non-oiled filter. The guy that sold it to me bought an AEM as a replacement :
The car has smoothed out over the weekend- seem to be running about normal.
Are you considering using a K&N with no oil?On the AEM no oiled filter, oiled filter FTL once and a while
You didnt see any dyno numbers in my post because I haven't done any comparison tests, and I certainly dont trust a 3rd party that SELLS intakes to do my tests for me.I'm sorry, I didnt see any tests referenced in your post. I thought the dyno numbers were pretty good. I also thought that they said that pretty much all intakes with tuning are about the same, and, from seeing how much higher intake air temps were with a short ram intake, if an intake is run, in my opinion, a cold air is best.
Welcome to the revolution!my SPT went on this weekend. super simple install, took less than a half-hour.
2 CELs on startup, MAF code and IAF code (whatever that is), but I erased em and they haven't come back after a couple of drives.
ca had a flat spot coming onto boost at low-mid revs--that's now gone. seems noticeably fatter powa in mid-range
sounds are just right...a leetle nasty without being totally hooligan.
Nigel is satisfied SPT fanboi now.
hunh...a modded Scooby with no CELs...what'll they think of NEXT?
I'm picking up what you're putting down now.I do completely agree that money is much better spent somewhere else, and I do agree that generally the stock airbox is better. I was just making the point that you CAN make more power with an intake look at this test. Any one can choose to, or not to believe the information in the test, but I felt it was a valid point.
So, I do stand by my previous point, that I agree with you, and you are right, for the most part.
