if what you are looking for is a turbo and not the ability to say I have an RSTi you can go with an AVO kit. way less money, and give a stock RS a pretty good kick in the rear. now if you dont have a lot of experience in the car this is no the kit for you. do suspension and winter safety school at team O's. you'll realize that the power is not necessaryThanks guys!! appreciate the input... when I first got the car I was just so exited to be in a subaru finally... but the wanting of a turbo just makes me to impatient... so I'm just gonna put a set of headers on it.. full exhaust, a good CAI and do some suspension workand enjoy the rs. It's a rare model.. I don't see many at all but Im sure there out there. keep saving and by this time next year well see where I'm at. with all this being said..I want to get it tinted to... but I can't find any places that won't charge me 300 to tint the rs... anyone know anyone/anywhere?![]()
The SOHC 2.5 is just as prone to HG failure, they just leak externally instead of internally.that kit has been run on many cars for years. and the SOHC engine isn't as prone to HG failure.
More common.....NO, more serious......yes, as in with SOHC they can still be driven if you keep the coolant level topped off.Wasnt this about putting that kit on a 2.5rs dual overhead cam engine? Headgasket failure on them is a little more common and more serious isn't it?
When my RS head gasket went, I was at an autocross. Threw in Poland spring and drove it the rest of the day. Drive it to Bangor and back a half dozen times before EG fixed it. The 2.5's aren't glass, they'll get you home if you treat 'em right.More common.....NO, more serious......yes, as in with SOHC they can still be driven if you keep the coolant level topped off.
Chances are the head gaskets were not done properly when replaced and/or the heads and block were not checked when they were replaced. They will lose coolant when they blow, but as long as you keep the level up, they will be fine for quite some time. However, if you don't keep up on checking the level, and don't watch the temp gauge, it WILL overheat, and cause damage to the motor, and possible warping of the heads, and sometimes the block. When replacing the 2.5 HG's, only use OEM updated Subaru HG's. Aftermarket ones WILL fail again. Another thing that is a must is making sure you follow the torque sequence very carefully.My buddies SOHC engine blew its HG twice on his 2002 OBS. Both times the engine started overheat and would eventually be missing coolant, preventing him from driving it because he couldn't go over 10 miles without stopping to cool down. I don't think he had mixing fluids but even so, is that the common failure mode for the SOHC and if so then how is that better/less serious than the DOHC which sounds like its driveable with a blown HG. Sorry to Hijack the thread, just curiosity getting the better of me.
