Chris
YARRR SUBY MONSTER!!
Well, check oil, bearings, etc. Until you check around it's gonna be hard to tell.
If you suspect it's coming from the transmission. Pull the trim around the shifter and pull the rubber boot off around the shifter base. If the noise is a lot louder coming out of the hole, it's more likely transmission .
Same for the noise from the rear. Check the bearings and the oil in the diff. What's on the drain plug tells a big story.
Put the seats down, have someone ride in the back and see if they can pinpoint the noise.
No amount of internet diagnosis is going to fix this till you do some investigation. We can point you in the right direction, but you need to do the work.
