04Exploder
what does it actually do. for example higher boost. what does it improve? who is running it. and what do you think?
Well he should have his definitions for the mods that his Stage 2 encompasses. Generally that would be a Downpipe at a minimum among other things. If you were thinking about it for you, and you have a VF39 as your SN says, likely this would not be for you. Unless specified it would be for a stock turbo.what does it actually do. for example higher boost. what does it improve? who is running it. and what do you think?
Nah.. I'm sure it was awesome but.. sometimesi had the vf39 but i sold it like a idiot
It doesn't mean Transmission problems and clutch failure automatically. I ran the launch control for a season of autox on my 04 and have no problems and I'm still on the original clutch at 104k miles.???
a stage 2 tune makes the car run more agressive with higher boost levels to take advantage of mods you may or may not have/sold. for a wrx you need a downpipe, an uppipe, and a K&N filter.
launch control makes it so that at the drag (and only at the drag!!!1!) you can floor the gas in first and it brings the RPMs to hover around where it's supposed to for a succesful launch, as well as priming the turbo at around 10psi.
launch control on an 05 wrx would probably mean transmission problems and clutch failure.
I don't think you will gain any boost unless anti-lag is tuned in for the launch control. The bouncing off the low rev limiter will get you about wastegate pressure I believe. it won't be like full on WRC launch control.???
now i know stage 2 all you need is downpipe uppipe and k&n, i have all that and i have headers, is that gonna benifit me too.
