Dude, if you do any mods above and beyond what the map is designed for you have to have it re-tuned. Somethings effect it more than others, particularly something like a CAI needs to have tuning done around it.that was good. lol . i dont think i need that, im not gonna be racing my car... i just downloaded xtp stage 2 with launch control for my car... i cant wait.. on the list of stuff you needed before you do this tune it said k&n drop in filter(which i already have) , could i run a cold air intake without any issues?
ooo, ok. just wondering, i dont know anything about this kinda stuff, i will keep to my stock intake system with my k&n filter. thanks for the input
Not really.... I've been running 11.5:1 a/f and sometimes a little leaner and 19-20psi and I haven't done that yet? So that is untrue.= KA-BOOM!!!![]()
I was referring to the trend, more boost + more lean = ka-boom.Not really.... I've been running 11.5:1 a/f and sometimes a little leaner and 19-20psi and I haven't done that yet? So that is untrue.
tuned that in a 3500' on the way to Rally NY with all of the tools and shiz in the back of the wag.I was referring to the trend, more boost + more lean = ka-boom.
Try flooring it up a hill in the 5th gear at like 30mph.![]()
Agreed. I ended up flashing back in a regular cobb stage2 map without LC cause I didnt care for it anymore.I have launch control and flat-foot shifting on my LGT. Launch control was fun for like 3 days but its pretty useless unless drag racing. You just look like a D-bag when you're sitting at a stop light at 5500 RPM. Flat-foot shifting is much more useful.
And my car won't blow up.. because I've tuned it properly.... Which at the same time, I think my RPM in 5th gear at 30mph (mind you I have much larger than stock tires) is much to log to drive like that.I was referring to the trend, more boost + more lean = ka-boom.
Tighten a half turn or full turn to raise boost. Do it in SMALL increments. Are you not hitting target boost? Care to post a datalog?when i downloaded the map. it says to adjust the wastegate arm to hit higher boost. do you turn the arm towards the engine or away from it, to raise it?
