Front hub is out. Blew up the ball joint and broke the head off the bolt in the hub for the ball joint. Will have to press out axle, and machine out that bolt to make way for a new one, along with new ball joint.
Rear strut bolts and trailing arm bolts are out, but the lat link is 19mm and I shattered the impact socket I was using with my breaker bar....
Pops is getting another metric impact set tomorrow. We also managed to get the air compressor working at full capacity again, the lines were done froze up.
Once the rear is out, it's remove the drum assembly and tone wheel then press both front and back axles out in da press.
Saturday is purchase parts at EG day. So far I need....
Front drivers ball joint, front camber bolt? Throw out bearing for FXT assembly, Possibly circlips all around for the axles?
Knowledge dump in the next post...
