GREASEMONKEY
--Powered By A.D.H.D.--
I have actually gone threw this before.....sucks!!!! but a press should work... just pay attention the how you set the hubs in the press I have accidentally flattened the strut bolt holes, ball joint holes and abs sensors trying to press out CV shafts and wheel bearings.. if this dose not go well I have sum front and rear hubs kicking around if ya need them... and it would be a good idea to replace the wheel bearings now.. especially on the stuck hub after the beating it has gotten the life of the bearing is greatly shortened. best of luck to you!! this is just prof to yall that a job that can be done in 20 min or less can turn in to a job that takes hours or days...
p.s.
on reassembly... never seize and assembly lube is your best friend!!!
p.s.
