abigailfisk76
I'm gonna have to get a loan to fix anything on it, so it's very tempting to do the swap, or try and sell it as is and buy something else
Thank you!!!!I know your pain! getting something used, whether it be car or motor would be scary, since you don't know how it's been treated.
But, may i suggest....
http://www.mainelysubarus.com/forums/topic/16033-built-bugeye-partout/
Only because it'd be ridiculous, in a good way.
or, on the cheaper end....
http://www.mainelysubarus.com/forums/topic/16057-sti-hybrid-w-stg-2-cams-etc-ss-headers-powdercoated-intake-mani-kevlar-timing-belt/
But also on the riskier end, since he's never even had it run.
If you wanted to play it safe and just fix your motor, I got a brand new block from subaru for $2300, and the kid at the dealership told me that no matter what block you get, the price is the same. (He was trying to talk me into an STi block)
Good luck with all of this!
yes. I was pointing out that all the blocks are $2300, so the block she needs is $2300. Then it's brand new with no miles on it and hasn't been possibly beat on.Any na block should be the same, turbo cars have different pistons= less compression with n/a setup
Definitely no need for a long block. And what are your intentions with this car? Are you going to drive it forever? Or are you planning on getting something else somewhat soon? If you plan on keeping it, I can see springing for the new short block. If not, get a good used motor and put it in. That's A LOT of money to be dumping into a regular Impreza. They are already going to rape you on labor for the install.From evergreen $2100 for the short block and $6100 for a long block
I plan to drive it as Long as I can. And a brand new block is only $300 more than one with 97k on itDefinitely no need for a long block. And what are your intentions with this car? Are you going to drive it forever? Or are you planning on getting something else somewhat soon? If you plan on keeping it, I can see springing for the new short block. If not, get a good used motor and put it in. That's A LOT of money to be dumping into a regular Impreza. They are already going to rape you on labor for the install.
Like the others have said as well, if you're getting charged that much even for a used block, you are already getting raped. Shop around, and don't listen to just the shop doing the work. Don't allow yourself to be taken advantage of!I plan to drive it as Long as I can. And a brand new block is only $300 more than one with 97k on it
