I'm totally stealing this idea! I have a set of 500FF's to mount and I was thinking of building a custom bracket much more elaborate than this.... but I just thought to myself...... "Why"? This looks so simplistic and effective. I think I need to get thicker stock, but I really love this idea! Thanks for posting these pics!Got 2 500FF's, never had any problems covers on or off. They are wired into the high beams (thanks to Dan for the help) and controlled by a switch inside so they are not always coming on with high beams, just when I want them to. 1/4inch aluminum hung off the front beam with 5.5inch bolts, barley any "dancing".
I normally wouldn't have a problem with this Chris, but I just got back to work (2nd week this past week) from 2 herniated discs and a pinched nerve. Been dealing with this since before Thanksgiving. I do not want to be on the ground, twisting, bending etc and throw my back out when I'm just starting to feel normal again! I could feel myself tensing up when I was out there from the cold so I did the right thing and came back inside. I'd throw out all of my progress made from PT, epidural injections, etc. Not worth it to me.It's Maine winter... cold is a bad excuse![]()
1.) As for the length, I would have to measure them. I cut the 48inch piece in half and drilled the first hole in the back and then mounted that to the car, and held the light up to where I wanted it and marked for the second hole and left about an inch in front of the hole as not to weaking the aluminum, my guess is it is about 10inchs, as the lights are only about 1/2-3/4iinches from the front of the car. **NOTE: I have about 3 washers between the bumper beam and the aluminum; otherwise the bracket hits and puts a lot of pressure on the front molding, so it needed to be dropped down a bit.2 Questions to Ray and KrazyKarpenter.
1) What was the length of your mount? I made mine 12" but that actually seems to stick the light out too far from the bumper... so I'm thinking of shaving an inch or so off.
2) Do you have issues with the mount pivoting? Since it is only bolted down by one hole/bolt, do you find them moving on you and not staying straight?
I tried doing a mock setup today, but my back still isn't good enough for bending/squatting/laying right now. Not to mention it's pretty cold out. I'll have to wait a bit longer before mounting them up.
