my 05 legacy
Well you have to put a fuse IN to be in FWD mode, so it is most likely something to do with the clutch packs in the center diff, or the solenoid that is in there.
I checked the fuse box under the hood, no fuse in the fwd slot. Saw something on legacygt.com bout a fuse for the awd in the dash fusebox, but I didnt see anything.
This is the first winter ive noticed it. I saw something bout the older legacys having a split, not sure of the 05s. Header is in the trunk still, haven't had money to get installed yet. Should be on by spring. Love tax season!!
Yes. Taxes=carparts=awesome.
On top of my awd not working, now my check engine light eith a flashing cruise light cane on today. car is sputtering some
Cruise flashes with a check engine light. Helps get your attention. If it is flashing drive it very little as its prob a bad misfire and can ruin your converters.
Bad misfire as in, a bad spark plug? bad thing only vehicle I got to get to work, 25 min each way,
