We shall be bringing the entire rad Jagdgeschwader up.
The dogbone looked ok...but it guess the bushings in it could be ok. With me pushing on it though i didn't hear anything. Not really sure where my clunking is coming from now. :it is directly under the intercooler. you should be able to see it from the pass side if you put your nose on the fender.
it is black and looks like a dog bone. it goes from the firewall to the engine.
LMAO I'll be at the June 24th event.. any idea what type of surface it is??![]()
;D
now the tricky part is to race in a competitive class in Rallycross. 2wd mod is where the party is!
w00t no more endlink noise! It was caused by a loose nut up where the bar mounts to it...it looks like it'll just loosen up again with more flexures in the sway bar. Maybe loctite is needed (or a washer to isolate the movement). Anyway she's squeak free now. Tomorrow is camber and tire day. ;D >>![]()
Almost ready to melt faces at orono >O0![]()
Andy definitely has better legsw00t no more endlink noise! It was caused by a loose nut up where the bar mounts to it...it looks like it'll just loosen up again with more flexures in the sway bar. Maybe loctite is needed (or a washer to isolate the movement). Anyway she's squeak free now. Tomorrow is camber and tire day. ;D >>![]()
Damn right. He has bigger jugs though.Andy definitely has better legs
Naw Mikey your all good.It's been since last year so I forget, do they tech helmets? Mine's a DOT only
Damn right.Andy definitely has better legs
