ruggedman
Hahah John referred to my g/f as Miss Street Mod when we were measuring the airport lot.Maybe he actually belongs in Street Modified... hahaha
is she all riced out?Hahah John referred to my g/f as Miss Street Mod when we were measuring the airport lot.Maybe he actually belongs in Street Modified... hahaha![]()
w00t no more endlink noise!
They would, but with the Aluminum control arms I kinda feel like the stock ones are like a fuse....they'll break before my control arms!Brandy newski solid endlinks would probably help too witht he giant sway!!! But good to know about the washer...washer between endlink bushing and locknut helps a lot in this case. also stick a fresh nylock nut on endlink that keeps loosening, sounds like your old one is poochedw00t no more endlink noise! It was caused by a loose nut up where the bar mounts to it...it looks like it'll just loosen up again with more flexures in the sway bar. Maybe loctite is needed (or a washer to isolate the movement). O0
She's got a couple nice mods done. ;Dis she all riced out?Hahah John referred to my g/f as Miss Street Mod when we were measuring the airport lot.Maybe he actually belongs in Street Modified... hahaha![]()
Guest Password = Pedrograndma! Your album is private!!! >![]()
Make it public so I can see the F*** up. >![]()
You should see about using it at the nat'l point rallyx on June 24th.It was good to see a bunch of forum members there this weekend, had a great time. It was good to see Mikey Rad again.
And yes, I will redeem that golden ticket you handed me for the leggy! I can haz cheezeburgr and learn to drive on dirt?
Showing off my 1st in class thingy to my girlfriend of coursewhere the hell were you sunday? you needed to defend your ESP title!
