cool, well I won't be in portland again until next monday, but we'll see what happens.If they can't check the code for you, I have a code reader ... I'm located in Portland ... let me know!
ffffffffffffffffuuuuuuuuuuuuuuuuuuuuuuyeah here in kenebec county theres no emission regulation like in cumberland county![]()
good to know. I have a friend (the one with the 1999 L wagonVIP in Yarmouth will pull codes for free if your buddy's dad can't/won't.
But then won't it just come back after a few minutes...?Unplug your battery for a min the CEL code will go away.
Only if there is a real problem. Sometimes you can get a CEL just from bad gas, or a loose gas cap. There is a thousand non-vital things that can cause a CEL, thankfully all the urgent ones cause a flashing CEL. As for the tick you heard, almost all subies over 50,000 miles develop a tick. Sounds like valve lifter noise, but from what I understand most of the time its the pistons making noise due to the way they are designed. No problem, it natural for a subaru. It ussually calms down when it heats up and can be further improved by using Synthetic oil if your milage isn't too high. Most likely your car wants a new O2 sensor. If you don't fix it you will be living with the CEL, the car will run fine anyway. Just another way that the VIPs of the world can make a $150 for a $25 part. If you do fix it they will probably make you wait and give you a song and dance about how hard it was to install, best thing to do is watch them as they install it, then they can't lie to you.But then won't it just come back after a few minutes...?
They don't cover much...It's still under dealer "warranty" so I'm taking it back to norm's for anything it needs.
Get it read, there is about a 5% chance it is something critical, but don't risk that 5% ... I'd do it for you, but I live 45 mins away.I know, but the battery terminals are very badly corroded. I don't want to risk "exposure" to undo either of the wires.
I specifically asked while we were buying if it would cover everything that would happen in the three months, and he said it would unless we took it to "generic parts store X" and they said "well, your exhaust is so bad that we have to replace it now or rip your inspection sticker off" then he probably wouldn't do it. He said as long as the car was actually checked out it would be fine.
We'll see how that goes...
I decided not to get the code read because I wanted to get home, and my dad says to just sit it out.
I can't believe you even said that...just don't touch both terminals at the same time!
fixedjust don't touch both terminals at the same time unless you wet your fingers first!
