2point5RS_Dan
HATER DAN
I'm not worried at all about digging into it. I've got my factory guides for the job, but I'll definitely keep your notes in mind. I've got all the tools, and I've been PB blastering every bolt I can see since I did the compression test.If it overheated at all definately get the head checked for warp. I had mine done by a machine shop in mt vernon. Overall easy job if your not afraid to climb up an sit on the motor. Make sure you label everything and put rockers etc. back in exactly the same place they came from. As long as you do that and follow the torque patterns, and teflon the one bolt that's in the coolant you should be set. Let me know if you need help or tools I did this to mine last spring. I think you need a 12 point socket on certain ones that is deep but also big enough to fit over the head bolt.
My parts labeling system is pretty good, blank cardboard, punch parts through, and write on cardboard with sharpie
Once I get a local shop to ok my heads I'll go ahead and do the reinstall in an afternoon. I'll probably post in my thread "hey I'm working on my POS jeep, come on over", I don't expect anyone to drive to the sticks outside of auburn to help me, but if you're chomping at the bit to help a random guy out I wont turn you away
