Loading this slut up with computer equipment to drive around new england for work last week:
Decided to do the rear O2 sensor today to try and get rid of the P0420 code.
Got the o2 sensor socket on and broke my last u joint. Tried hammering the socket around but it wouldn't budge. Heated the bung up cherry red. Broke the bung off. Dropped the exhaust.
Booger welded the bung back on and got the new O2 sensor in:
It actually worked out well, because the shitty rock auto header gaskets were leaking at the cyl head. I had RTV'd them to pass inspection but it wasn't cutting it. Went to the dealer this afternoon to get my snow tires mounted for the RS and get new nice gaskets.
Got the exhaust back on. Welded up one of my broken hangers. Got the new gaskets in. Everything good to go.
Go to clear the code and the legacy didn't want to start. Get it going again and the airbag and ABS lights stayed on longer than normal. ABS light is still on. Didn't do the trick to get the DTCs, but tomorrow I'm going to pull the battery and see if that clears it, then get the DTCs.
Also put the new snows on the legacy and they're balanced fine, just noiser than the DSWs, which are on the RS just to hold it up and to pass inspection. The car looks so boring without the snowflake rims.
Also did this with the android torque app on the way home tonight:
Sllllloooowwwwwwww
YESTERDAY:
Rick came over yesterday and was a huge help.
STi struts ready to go in.
Issue. I didn't have bump stops. I thought I could ream out my stock ones to fit the increased diameter of the STi strut. Nope.
While taking the front strut out. I accidentally tore apart the axle.
fudge
Put it all back together because it doesn't matter. Replacement on order for long trips.
While taking apart my rear clunking strut.
Yeah, that top hat is ovaled.
We put it all back together with the tokicos. We welded a few washers in and re-drilled the top hole. No more oval. Put it all back together and the right side doesn't clunk, but doesn't adjust anymore. Left side now clunks.
Put RTV on the exhaust leak that I can't get the welder to. Belts are in. Took the cluster out. Dad tried to knock out the door ajar, abs, and airbag lights. Got everything but the airbag light out and he screwed up the odo. He's taking it to work so he can do a proper job.
Later on I found out....
The LOVING bump stops are in the LOVING STi strut. I could have installed them.
So next weekend is put STi struts in and shake down.
