like i-wagon said Rustoleum:What I was wondering was whether there was a primer that could seal it well enough to "cut off the oxygen" to prevent the rust from spreading. I don't actually know whether or not rust needs external oxygen to spread though.
Yeah I noticed that the hub had a sort of "built-in" battery connector, but there's a spot or two that I wouldn't be able to reach on the passenger side of the car if I mounted it where its supposed to be.what i did with the "hub" was mount that directly to the terminal. now if you take the top part off, your negative battery cable will slide over that piece, clamp and put the top on.
There's only 5 grounding points I want to connect to, so I can use the extra (6th) cable you gave me to run back to the battery, therefore eliminating the need for the hub to be grounded.and i have no idea where you'd want to mount that thing.... just make sure it's a clean connection (no rust)
I believe its fine in that respect. I'm just concerned that its not going to ground well.The front tires are supposed to be like that when they are turned, and it looks like that grounding wire has a chance of rubbing on the belts
