Nigel Prodrive
Dirt surfer
actually, it's more like, "if you don't know how to countersteer, all you'll have left is a parts car."if you don't know how to countersteer buy a parts car!
maybe on pavement. but on rough dirt, big bars inhibit a Suby's suspension travel which is entirely counterproductive. on the LDR rally car, we often disconnect the swaybars entirely, esp on snow.I'm assuming upgrading the front a bit as well will prevent it from being as snappy?
Taken from Modified.com's article on suspension and handlingTires by far are the biggest contributor to finding more cornering force. By bolting on a set of stickies, you-in minutes-make the biggest possible gain in cornering power. Generally, putting the biggest tires that will fit inside your wheel wells without rubbing is the way to go. Choosing an ultrahigh-performance tire is also important.
If your just driving around on the street, then get a big rear sway bar. I did it, and it was a huge upgrade.
^THISactually, it's more like, "if you don't know how to countersteer, all you'll have left is a parts car."
Go to a body shop and they'll be able to match it for you.Sweet, thanks. Unforunately, I only have the code for Silverthorn Metallic, not the bottom color.
Last weekend I wanted to tighten one of the bolts on my stock mudflaps (the plastic isn't too flappy though), and I couldn't get to it with the wheel on. I couldn't find my tire iron either. I'm going to look for it, but it might be time for my first parts-yard trip.
What exactly are you doing with the clutch?I can't figure out when to stop tightening the clutch cable bolt... I was able to loosen the locking bolt and I'm trying to see if I feel a difference anywhere when tightening the other bolt. So far no luck.
