As am II will admit I'm looking forward to having some fun in the snow with my car
Make sure you have something to get pulled out of snow banks withAs am I.
You don't want to find out the hard way...Lol... I have a tow strap, but its only rated for 2k pounds. When (if!) getting pulled out, will the strap be under more or less pressure than the weight of the car? I'd assume less unless its down a slope.
all depends on how hard you stuff the car, doh!Lol... I have a tow strap, but its only rated for 2k pounds. When (if!) getting pulled out, will the strap be under more or less pressure than the weight of the car? I'd assume less unless its down a slope.
Sweet picall depends on how hard you stuff the car, doh!
for most minor offs into a snowbank, 2k rated strap will be no prob. generally the load on a tow strap is limited by the tow vehicle's traction...he's on the same slippy roads that you went off on originally.
it's also amazing how strong a pull you can get from a few bystanders just yarning on the strap---here's the LDR car getting out of a big stuff at Team O'Neil Rally last winter (kudos to Pete Kuncis for great foto)...and yes, we did get car out (eventually).
Ahhh, now that makes sense. The name kinda implies it. I asked while on the phone with a friend of mine complaining about his life... I forum while I'm being complained to. heheI believe it stretches, hits some critical point, and then pulls back on itself.
I don't use them on much these days. the tow points on some of the rally cars aren't all that sturdy.You would be correct sir.
It allows a running start when extracting without too much risk of damage from the sudden snap, and offers a bit of extra force with the bungie effect.
That's because cars are making it through tech that shouldn't...the tow points on some of the rally cars aren't all that sturdy.
